could VATS cause car to turn off?
Old May 2, 2023 | 10:47 AM
  #51
george88gta's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
Re: could VATS cause car to turn off?
I'm pretty sure my problem wound up being the harness that runs behind the driver's side head
the ground bolt that sticks out of the back of head was inside the loom I can't be sure but since I adjusted that harness I never had the problem again.
Old May 2, 2023 | 11:12 AM
  #52
ksr's Avatar
ksr
Engine: 5.7 liter V-8
Transmission: 4 speed auto
I'll have to check that out George, Thanks.
One other thing. When my car died, at first I could hear a light ticking noise near the battery. I couldn't tell exactly where the noise was coming from. Not much there except for the headlight and maybe the windshield washer pump. I thought that maybe there was something wrong with the headlight motor on that side which kept it running at some low level and drained the battery.
Old May 4, 2023 | 04:26 PM
  #53
Engine: 5.7 l98
clicking maybe the iac under throttle body
Old May 7, 2023 | 03:40 PM
  #54
ksr's Avatar
ksr
The car was completely dead. No crank, lights, horn, anything. I pulled the fuse out of the fusible link in front of the battery. It looked fine, not broken or burned. Figured that wasn't my problem. Put the fuse back in, and the car came back to life. All seems normal now. The power was so completely out that the radio was locked and the time and presets were erased. This doesn't exactly inspire confidence in driving it any great distance from home, but at least I'd know where to start looking.
Is there any chance that pulling the fuse reset reset something? Or is there probably a short that I temporarily fixed by playing with that line?
Old May 7, 2023 | 04:15 PM
  #55
Engine: 5.7 l98
a fusible link doesn't have a fuse to pull it's just a thinner gauged wire meant to burn up before anything else
Old May 7, 2023 | 04:33 PM
  #56
ksr's Avatar
ksr
I guess I didn't know what a fusible link was. Thanks.
I did pull the fuse attached to a wire in front of the battery. It's held in a plastic holder that is screwed to the frame. Put the fuse back in place, everything came back to life.
Old May 7, 2023 | 04:53 PM
  #57
Engine: 5.7 l98
link is by the starter above the metal shield. I would trace that fused wire and look for issues.
Old May 7, 2023 | 04:55 PM
  #58
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
the fuse is for ecm power and fuel pump. Might have a excessive pump draw.
eliofall
Jul 4, 2011 08:23 AM
Motopsyco
May 13, 2010 11:18 AM
Maverick H1L
May 17, 2009 12:44 PM
CanadianBeast
Sep 23, 2003 01:22 AM
StuckThrottle
Apr 17, 2002 03:44 PM
