What do these go to?
Old Apr 19, 2009 | 06:25 PM
Devryn's Avatar
Any ideas? First one is near the passenger strut tower. Second one is drivers side firewall.
Old Apr 19, 2009 | 09:33 PM
baliva1's Avatar
Re: What do these go to?
the top one has to do with the Smog Pump system and a sensor that used to go with it (guessing it has been removed off your car) - no problem with that one, you shouldnt get an engine light with it un-hooked.
I'm not positive on what exactly the 2nd one does, but I know that its supposed to plug into a relay that bolts to that black metal to the right of the other relay in the picture. It looks like you are missing the relay it plugs into.
Old Apr 21, 2009 | 09:57 PM
macertheracer's Avatar
Car: '91 RS CP now is the son's driver
Engine: CP =3.1, will get V-8 maybe someday
Transmission: stock
Axle/Gears: 3.42 posi W/ disks
probably fuel pump relay, has your car been converted to carb?
