which one is the fuel pump relay ??
Old Apr 19, 2009 | 09:33 PM
92RSStud's Avatar
Car: 1992 Rally Sport
Engine: 355CI
Axle/Gears: 10bolt stock gears
the left or right one?
also what are these three wires for. (orange red and green)
wires003.jpg?t=1240194641
and what does this green wire go to on the other relay?
wires001.jpg?t=1240194781
And what is the connector with the prongs sticking out for? (right in front of the two relays)
Old Apr 20, 2009 | 08:42 AM
IroczInOz's Avatar
Re: which one is the fuel pump relay ??
Easy way to pull one relay and start the car. If you hear the fuel pump prime and start you know that is not it. So try the next one.
That is how I found mine. I know on my 86 camaro, the power to the fuel pump relay comes via a thick orange wire.
Old Apr 20, 2009 | 10:34 PM
marine68's Avatar
Car: 89 IROC Z28
Engine: 5.7 L Edelbrock perf /holley 3310
Axle/Gears: BW 9 BOLT 3:27
the one with the prongs is your electronic spark control module, the other two are maf power and burnoff relays. the fuel pump relay is a 5 pin straight connector. my 89 iroc 350 is like this.
Old Apr 24, 2009 | 10:28 AM
Pocket's Avatar
Car: 91 Trans Am
Those are Fuel pump relay and Fan relay, not MAF/burnoff relays. Those are elsewhere
From the ESC module Id assume you have a LO3, and being unplugged Id assume a carb swap
The relays are in upside down (doesnt affect operation)
Id guess the first pic is the fuel pump relay with the Orange (12v battery) Red (test lead) Green (ECM enable) Gray (output to fuel pump)
It is easiest to identify by the test lead, sometimes its 6" long near the relay, but Ive seen them ran across the engine near the AC box
The function is the same, add 12v, the relay clicks on and the fuelpump enables
The second relay is most likely the fan relay
It should have heavy Red (12v battery) Black (ground) Green (ECM enable) heavy Black w/ Red stripe (fan output) Brown (Alt/fan common at C100)
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
