Alternator - extra wire
Old Apr 14, 2009 | 08:58 PM
thekevin's Avatar
Car: 1985 Z28
Axle/Gears: 3.23 open
I have an 85 Z28, 305 TPI, how many wires should be coming from the alternator, i have the two prong plug and the only wire on it is just a short jumper back to the alternator, i found another black wire that the only place it looks like it can plug in is on the other side of that two prong plug, any info?
Old Apr 24, 2009 | 10:45 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Alternator - extra wire
ALT plug should only have two wires
Red 12v from some constant hot source. Either power distribution block or a lead off the battery cable side of the starter
Alt will not charge without this wire
Brown alt gauge which goes thru the C100 connector
Not required to run
Old Apr 24, 2009 | 11:59 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
The red wire is the voltage regulator reference source and is customarily jumped over to the alternator output which is connected to the battery via the starter.
If the brown wire isn't hooked up the alternator rectifier won't get excited at low RPM. It is hooked up to the gauge and battery warning light normally. If you hook it straight to battery power it will fry the rectifier in short order. It needs a bulb or resistor between it and a keyed (ignition on) power source.
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
