Oil Pressure Sending Unit so my gauge works
Old Apr 21, 2009 | 12:04 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
I have a 1992 Firebird 3.1L and I put in a gauge cluster from a Trans Am, but I need to switch out my oil pressure sending unit. The one for the V8 is too big (at least it was when I went to the Zone to pick it up), do I need to get an adapter for this to fit, or is there another one I can use? My buddy did this with his Camaro, but I guess the Camaros have a more universal sending unit, as one from an IROC fit his 2.8L.
Old Apr 21, 2009 | 08:53 PM
macertheracer's Avatar
Car: '91 RS CP now is the son's driver
Engine: CP =3.1, will get V-8 maybe someday
Transmission: stock
Axle/Gears: 3.42 posi W/ disks
Re: Oil Pressure Sending Unit so my gauge works
either or your choice just as long as it is a GM sender, """"DO NOT USE ANY KIND OF SEALER AT ALL''''' if you want the guage to work sealer acts as an insulator
Old Apr 22, 2009 | 07:26 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
So thats the only thing I can do? Adapter?
Anyone know the thread size of the block and of the V8 oil sending unit?
Old Apr 22, 2009 | 08:45 PM
Transmission: stock
No No No you can get a "GM" sending unit for your block and it will work fine IF YOU WANT OR YOU CAN USE AN ADAPTOR it is your choice
try one from an IROC GM sending units all work under the same theory
Old Apr 22, 2009 | 10:28 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Seeing as how the Camaro oil pressure sending unit has one spade connector and the Firebird has three prongs, its not a plug and play. I guess if I wanted to cut my harness up I could wire it, but thats not what I'm after. I want a FIREBIRD style connection on an oil pressure sending unit that will work with the V8 gauge and fit into my V6 block. Now if that means an adapter, great, I just need the thread sizes like I asked before and I can do that. If there is another oil pressure sending unit, maybe from a different year or anything along those lines, that would be good too.
Old Apr 22, 2009 | 11:06 PM
Transmission: stock
oh man I AM SUCH AN IDIOT i thought you were talking like they were the same years, man why did I not read your mind, what an idiot , someone oughta kick me in the keaster.
sizes 1/8th inch pipe (small one) 1/4inch pipe (bigger one) for OIL PRESSURE FITTINGS sheesh
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
db057
Aug 22, 2015 08:17 PM
justin57
Aug 20, 2015 07:05 PM
Irocohio
Aug 12, 2015 08:03 AM
