fuel relay help
Old Apr 21, 2009 | 08:04 PM
92RSStud's Avatar
Car: 1992 Rally Sport
Engine: 355CI
Axle/Gears: 10bolt stock gears
fuel relay help
Hey guys i'm needing to bypass my fuel relay to make the pump prime... i swapped in a 355 carb from my 305tbi and need to know how to hook up my wires so i can get my fuel relay to either work properly or just hook up to an "hot in ignition" wire because i have hooked power to all but the ground on the relay and i got nothing... (other than the normal clicking sounds of the power switching.)
Help?
Old Apr 21, 2009 | 09:22 PM
92RSStud's Avatar
Engine: 355CI
Re: fuel relay help
never mind, had a faulty ground.
Old Apr 21, 2009 | 09:30 PM
macertheracer's Avatar
Car: '91 RS CP now is the son's driver
Engine: CP =3.1, will get V-8 maybe someday
Transmission: stock
Axle/Gears: 3.42 posi W/ disks
Re: fuel relay help
wow!!!! my mind went into over load for a minute, trying to remember the wire color codes, but next time there should be a white, or red, maybe a combination of red/white with a plug on it near the fuel pump relay. that is your bypass line.
Old Apr 21, 2009 | 11:06 PM
92RSStud's Avatar
Engine: 355CI
Re: fuel relay help
its actually grey.
The green/white wire goes to the relay coil side
The black wire goes to ground
the Red wire comes from the fuel prime switch to one side of the switch relay
The Orange Wire comes from the ecm to the other side of the switch
And a grey wire is on the opposite side of the switch and runs to the fuel pump.
Old Apr 21, 2009 | 11:28 PM
Transmission: stock
Re: fuel relay help
Originally Posted by 92RSStud
its actually grey.
you are right like I said I went into overload and I am 50 so I get handicap bonus points
Old Apr 21, 2009 | 11:53 PM
92RSStud's Avatar
Engine: 355CI
Re: fuel relay help
for sure :-P
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
Caspar
Jun 19, 2016 11:19 PM
Kaweh
Aug 9, 2015 02:54 PM
