fuse blew and keeps blowing
Car: 89 Formula
Transmission: TH 700R4
Fired up the car again today and was going to take the T-tops off and go for short cruise.
Press the hatch release, nothing. I notice the pw antenna did not come up....p. mirrors are not working..
Check the fuse..it blew. Popped another one in..blew.
Now I recently had the pw antenna replaced. If a power wire came off could it be shorting the fuse out??
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 1987 IROC (parts car) '86 IROC
Engine: 5.7, None
Transmission: 700R4, None
Re: fuse blew and keeps blowing
Yes. If the power wire to the antenna is loose and touching ground, it will blow the fuse.
If the power mirrors and hatch release are on the same circuit, that would explain why they don't work as well.
The obvious aside, is there a chance the antenna motor is bad? Was it a used unit? Did it sound bad when it operated? Any chance the aerial could be binding?
Unless someone just ran wires to your antenna motor (bypassing the connector provided) the power wire is probably still attached.
Car: 89 Formula
ok thanks. No it's brand new antenna. Back it goes to the shop for free fix.
I have had problems with my cars battery too---not sure if its related. It is 9 years old---but it sure went down hill fast!
reminds me of the time when i first tried to use my cig lighter after buying my car 2 years ago....it started shooting sparks at me. good idea to try this.
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I'd check the cig lighter aswell, if not check the upper console (if applicable) or the dome light...anything that might be close to exposed metal...
