Pulling my hair out... code 42 & other electrical problems...
Old Apr 24, 2009 | 09:35 AM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
I'll keep this short and sweet, 1989 Formula Firebird 305 TPI (original)
Here's a list of things i've experienced with my car:
1) My ECM will go bad every year or so.... I'll get an SES light, change the ECM and the SES light will go away.
2) I have code 42 now, the car seems to only have the code when it's cold. After the car warms up, if i shut it down and start it back up, the code usually goes away.
3) Recently, my radiator fans stopped working (probably a seperate problem). I had been swapping the relays for the radiator fans and the HVAC fan recently, could my problem be that I burnt out my relays from switching them?
4) I recently probed all of the ports on the ECM with the car off, and the key on, and all of the voltages seemed to match the values below:
Key on Engine off:
A1 - 12v, A2 - 12v, A3 - 12v, A4 - 12v, A5 - less than 1v, A6 - 12v, A7 - 12v, A8 - 2-5v varies, A9 - 5v, A10 - Speed Signal, A11 - 0v, A12 - 0v,
B1 - 12v, B2 - 0v, B3 - 0v, B4 - not used, B5 - 0v, B6 - 2.5(vats), B7 - 9.2, B8 - 0v (A/C off) or 12v (A/C on), B9 - not used, B10 - 0v or 12v (park/neutral switch), B11 - not used, B12 - 2.5
C1 - 12v, C2 - 12v, C3 to C6 - not usable (IAC), C7 - not used, C8 - 0v, C9 - not used, C10 - 1.7v (varies with temp), C11 - not used, C12 - 2.0v, C13 - .54 (TPS signal), C14 - 5v, C15 - 12v, C16 - 12v
D1 - 0v, D2 - 0v, D3 - 0v, D4 - 0v, D5 - 0v, D6 - 0v, D7 - .35v to .55v (O2 sensor), D8 and D9 - not used, D10 - 0v, D11 - 12v, D12 - 12v, D13 and D14 - not used, D15 - 12v, D16 - 12v
5) When I have code 42, the car runs badly.... there is still spark advance according to my laptop, but the car goes nowhere when i floor it.
6) When I have no SES light, the car runs perfectly fine.
Old Jun 9, 2010 | 08:33 AM
bigchief's Avatar
Re: Pulling my hair out... code 42 & other electrical problems...
this ended up being a bad ECM..... for those that care
Old Jun 9, 2010 | 12:00 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
next time the ECM goes bad, you said they blow yrly, open it up and see what part of the board is frying if so, that can help allot.
I was ready to goto a carb till I figured it out at the last sec
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
stalkier
Aug 21, 2015 01:54 AM
mizz0313
Aug 12, 2015 06:45 AM
