Charging Question
Car: 1987 IROC
Axle/Gears: 10-Bolt 3.73
Charging Question
Yesterday on my way home i noticed my volt gauge was reading under 13 volts. When I got home I put a multi-meter on the battery and it read 11.92 volts with the engine running. Today I went back out to investigate the problem and got 12.41 volts with the engine off. Then I started the engine and tested it again and it still read 12.41 but then all of a sudden it jumped up to 14.39 volts. So, I'm thinking it must have a bad internal voltage regulator?? What do you guys think? Thanks
Car: '91 RS CP now is the son's driver
Engine: CP =3.1, will get V-8 maybe someday
Transmission: stock
Axle/Gears: 3.42 posi W/ disks
Re: Charging Question
yes or a bad connection......... Ground, Alternator plugs, alt' power connection...?
Car: 1985 Z28
Axle/Gears: garbage 2.73
14.39 sounds right for a properly charging alternator. Try taking a reading while keeping the motor at 2000rpms. If youre still getting 14+ vdc, try bumping the the throttle to give the regulator built into the alternator something to regulate. The faster the alternator spins.....meh, not getting into the theory of a PMG.
Car: 1987 IROC
gixxer92
Sep 1, 2015 04:32 PM
db057
Aug 11, 2015 10:11 PM
