hatch switch
Old May 2, 2009 | 07:35 PM
CodyC123's Avatar
Car: 86 Z28
Engine: 385
Transmission: T5 (soon to be in pieces)
Axle/Gears: 3.73 POSI Disc
hatch switch
ok so my hatch switch was broken so i threw it away figuring if i needed the hatch open i could just jump the orange an brown wires that went into it, this doesnt work and neither does my key. i need to get it open so i can install new shocks tuesday. any ideas?
o ya my key doesnt work because the lock was changed, not electrical issues
thanks
Old May 2, 2009 | 08:34 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Re: hatch switch
By any chance is your interior plastic still off in the back where the lock cylinder was changed? If so, it's easy ... just crawl back there and you can pop it with a flat screwdriver. If the plastic is still on, it's going to be tough to get to because of the two little phillips screws on top of the plastic on either side of the latch. You might be able to undo the plastic interior screws around the plastic panel and lift it up enough to get in there to pop it. But you run a risk of damaging your plastic. That's the only way I know. I'm sure there are others.
Old May 3, 2009 | 09:29 AM
CodyC123's Avatar
Car: 86 Z28
Engine: 385
Re: hatch switch
no the lock was replaced before i bought the car is there anyh reason why it would work with the switch but not with a jumper wire?
Old May 3, 2009 | 10:26 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
Re: hatch switch
How bout another switch.......ur gonna need it anyway
Old May 4, 2009 | 10:47 AM
CodyC123's Avatar
Car: 86 Z28
Engine: 385
Re: hatch switch
obviously, ijust wanted to know if anybodyknew of a trick icould use just to get it open so the shocks can be installed, i dont have the cash right now for a 20 dollar switch
Old May 4, 2009 | 10:54 AM
jaygod8's Avatar
Car: 1986 Camaro Sport Coupe
Engine: 2.8L V6
Re: hatch switch
Connect / Run a wire from you're fuse box (1 of the BAT Spade openings with constant power) to the Brown wire (that should be the wire running to the release solenoid). This should "pop" your hatch. If that doesn't work, then your switch was probably okay and your solenoid is probably bad. Hope this helps!!
punkmaster98
Sep 30, 2015 11:01 AM
tglennon11
Sep 23, 2015 05:30 PM
Randomtask2
Sep 10, 2015 08:37 AM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
scottmoyer
Sep 7, 2015 07:06 PM
