really easy question please help
Old May 3, 2009 | 08:26 PM
SSZ2891's Avatar
these interior components dont work: power locks, radio resets everytime i get in the car and so does the clock, the overhead lights dont work, and horn. i think its fuse acc 20a. where can i get the same fuse? how many amps is it 20 amps?
Old May 4, 2009 | 05:36 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: really easy question please help
Yes, 20A accessory fuse.
If your fusebox is still readable, it should indicate the required fuse amperage for each circuit.
Hope this helps.
Lou
Old May 5, 2009 | 11:14 AM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
I may be wrong but I think the radio problem is separate. Is it an after market radio? The red wire(on most radios) should be connected to a fuse that only comes on when the ignition is turned on. The yellow wire which runs the clock should be connected to a battery fuse which has power going to it constantly. That will run the clock and the memory for your station presets. Hope that helps.
Old May 5, 2009 | 11:18 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
you need to tell us the year camaro you have. i have the wiring diagram for the 90.
decided just to give it to you instead of waiting - hope you are close to 90. you can click on pic to see it but a real good pic will be to download it and then look on a pdf reader where you can really expand it.
File Type: pdf
Old May 8, 2009 | 08:01 PM
SSZ2891's Avatar
its an 89 camaro iroc 305 tpi. just put another fuse from my fuse box it said 20 on it into acc fuse 20a and it created a spark??????
Old May 8, 2009 | 09:30 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
something is shorting out. I would check your cigarette lighter which is usually the main culprit, then the overhead console/light...good luck!
Old May 9, 2009 | 10:47 PM
SSZ2891's Avatar
just put a new fuse in it and it blew the new fuse immediately. what would cause that
Old May 9, 2009 | 11:03 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
You have a short. If one of the wires become frayed and makes contact with the metal frame or sheet metal, the circuit will surpass its current flow capacity (amps) and will blow the fuse. The question is what caused the short and how to find it? You'll have to find out what components work off that fuse. Unplug each component and replace the fuse. If it blows you have a bare wire touching metal somewhere. If it doesn't, plug in one component at a time until the fuse blows. Then you can isolate where the short is.
Old May 10, 2009 | 10:36 AM
BigBadLou's Avatar
Engine: TPI
A neat trick to avoid blowing dozens of fuses (they can get expensive) is to use a regular 99c test light instead of the fuse. If all devices with a draw are disconnected (dome light bulbs removed), the light should be turned off.
As long as the light is lit brightly, there's a big draw in the circuit (likely the short). Just trace all wires and devices on that circuit, wiggle wires, pull connectors, until the light turns off.
Hope this makes sense.
Lou
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
BurlyChev
Aug 16, 2015 09:08 PM
