No voltage to a/c compressor
Old May 5, 2009 | 03:13 PM
Glump's Avatar
Car: 1987 TA
Engine: 5.7 TPI
I have checked and tested every fuse in the block under the dash.
Guess i'll check the heat-a/c control in the dash next.
Am I forgetting to check something?
Old May 5, 2009 | 03:20 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Re: No voltage to a/c compressor
im positive there is a relay somewhere under the hood. i dont know exactly where but thats when a good shop manual comes in
Old May 5, 2009 | 07:40 PM
Glump's Avatar
Car: 1987 TA
Engine: 5.7 TPI
Turns out its a bad presure switch...
Old May 6, 2009 | 10:11 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Yup, a bad pressure switch (or no pressure in the A/C lines) will cause a no-power situation at the compressor clutch.
Diagram here: http://www.austinthirdgen.org/mkport...F_and_vin8.jpg
Which switch is bad? The low pressure cycling switch in the drier or the high pressure switch in the back of the compressor? The first one would be easy to replace (and they do tend to go bad often).
Lou
Old May 6, 2009 | 12:06 PM
Glump's Avatar
Car: 1987 TA
Engine: 5.7 TPI
Yep..
It was the low presure switch...all fixed now
Elephantismo
Feb 13, 2019 12:51 AM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
