Fuel Pump Priming Issue
Old May 5, 2009 | 09:52 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Having an issue with my fuel pump not kicking on.
I checked the relay and I have power to all the right connectors except for the grey wire, which I believe works with the ECM and triggers the pump to turn on when I turn the ignition over (correct?). When I complete the circuit, the pump turns on just fine, so I know it isn't the pump. And I am getting power to the relay box and to the pump (obviously). It is just that grey wire that runs from the ECM that tells the pump to turn on when I turn the key to the on position is what the problem is. To help troubleshoot it, I am trying to see where it has power and where it doesn't. It doesn't near the pump.
Anyways, I want to test it at the ECM, but there is a number of grey wires coming from it. Is there a diagram out there that can help (online)?
I found this link
http://www.austinthirdgen.org/index.php?pid=35
But it doesn't have a diagram of what the fuel pump priming wire (grey wire) is at on the ECM.
Or if you know of a better way of tracking it down in the engine bay area, that would be great.
Many thanks.
Old May 5, 2009 | 10:02 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Fuel Pump Priming Issue
So, is the pump not priming, or is it priming but not running? I'm confused on what the problem is.
Old May 6, 2009 | 10:15 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
You found the right link.
When you open it, click on the words that say "WIRING DIAGRAM". That's your wiring diagram.
The wire which the ECM uses to control the fuel pump relay is dark green/white in color.
The grey wire is what powers the fuel pump when the ECM actuates the relay, you should see power on it when there is power on the green/white wire which actuates the relay.
Hope this helps.
Lou
Old May 6, 2009 | 11:44 AM
92RSStud's Avatar
Car: 1992 Rally Sport
Engine: 355CI
Axle/Gears: 10bolt stock gears
my guess would be the relay switch has gone bad... because it should send power to the grey wire once the key is in the on position... the grey wire has nothing to do with the ecm... it goes from the relay to the pump.
So i would suggest replacing the relay.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
