heater motor trouble!
Old May 5, 2009 | 11:42 PM
Regal105's Avatar
Car: 83 c10, 2015 silverado
Engine: 454, 5.3
Transmission: Turbo 35o, 6l80
Axle/Gears: 3.42, 3:23
hi, i have a heater problem with my 90'rs ever sence i had it "about a year" it's been blowing heater fuses regularly and i didn't know why so i pushed a piece of metal in a blown fuse and stuck it in the plug "not smart i kno" and forgot about it everything worked perfect till about a month ago when i splashed through a big puddle the heater died all the lights flashed and i smelt this electrical burnt smell, now when i turn on the fan it will go for a little while stop and if i turn up the speed it will pull down the volt metre at the first setting and short the car out and stop it at the 2nd position!, any ideason whats doing this the switch maybe? thanks in advance!
Old May 6, 2009 | 08:51 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
BLOWN MOTOR
Test the blower motor.
Do this by isolating the power input, then applying 12 volts directly to it thru a fuse.
If the motor can operate for a half hour or so without blowing the fuse or overheating it means the problem is in the wiring to it.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. Keep em turned off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
1992 Trans Am
May 10, 2023 07:19 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TheExaminer
Aug 26, 2015 04:59 PM
1985chevydude
Aug 22, 2015 05:36 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
