Spark timing problem
Old May 7, 2009 | 08:36 AM
Brads RS's Avatar
I had this on the TPI board but no one had any answers, so i thought i would give the electronics board a try.
Ok I have a 92 TPI Camaro with a 355 and mild cam. The engine had been running fine but i started to notice the engine starting to knock under a load. I traced it down to the timing. The timing never advances and is out of the timing marker on the retarded side when it is running, and out of site when you put the engine under a load. Its kinda like its doing the opposite of what it should be doing. I have tried a new ecm, new prom, new dist. module, new knock sensor, and cannot under stand whats making it retard the timing so much. If i unplug the timing advance wire and run base timing its fine, no knock and its rock steady on 6 degrees. I'm at a loss i'm not sure where else to go. The only other thing that i should mention is the car was a 6 cylinder and i re wired it for the v8. I have double checking the wiring but i doubt the problem is there since this problem has just showed up and it worked fine before. Any direction would be great. Thanks in advance, Brad
Old May 8, 2009 | 07:24 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Re: Spark timing problem
Your positive it wasn't dis-advancing the timing before?
Old May 8, 2009 | 10:48 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Have you checked the harmonic balancer? They are known to slip sometimes and give incorrect timing readings.
Lou
Old May 11, 2009 | 08:31 AM
Brads RS's Avatar
I will check the balancer tonight and see if that may have slip. Thanks for the input, i'll let you guys know how it turns out.
Old May 12, 2009 | 08:06 AM
Brads RS's Avatar
The balancer is fine it has not slipped. Any other ideas?
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
