blower motor
Old May 8, 2009 | 01:40 PM
19Maro91's Avatar
Car: Camaro
Engine: 305 TBI
blower motor
my blower motor is not turning off when i turn the **** to off on the a/c control panel. any ideas???
Old May 8, 2009 | 03:09 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: blower motor
If it's blowing at high speed even with the controls set to OFF, it's likely that the hi-speed relay on the blower is stuck closed, powering the blower constantly.
The relay is under the hood, on the side of the blower/evaporator housing, standard oval GM relay. If you disconnect it and the blower stops, that's your problem.
If the relay is bad, you have three options:
1) leave it unhooked but you'll lose the high speed on the blower
2) buy a new relay ($5-$10)
3) open up the current relay and clean/file down the contacts (unless the relay is burned)
Hope this helps.
Lou
Old May 10, 2009 | 09:44 AM
19Maro91's Avatar
Car: Camaro
Engine: 305 TBI
Re: blower motor
its blowing at the speed the speed control is at. Say its at the off position and the speed control is at high then it blows high, if in low it blows low. also when the control is in the heater setting it blows like it would in defrost. another thing is there's a burnt metal smell coming through the vents when i accelerate from a stop. any ideas? all these problems seem to be happening at the same time. thanks a bunch
Old May 10, 2009 | 10:48 AM
BigBadLou's Avatar
Engine: TPI
Re: blower motor
Then it's likely that the A/C control head is bad (the switch that selects the function of the HVAC). Diagram here to explain: http://www.austinthirdgen.org/mkport...C60_manual.jpg
If the ducting selector doesn't select the right ducts, you might have a vacuum supply problem (if it always blows at the windshield) or the switch problem (if it switches between wrong ducts).
The burnt metal smell probably comes from under the hood, it's pretty normal on our old cars to get the smells from under our hood due to failed hood seal allowing air to escape the engine compartment and enter the HVAC intake under the windshield.
Lou
Old May 15, 2009 | 11:22 AM
19Maro91's Avatar
Car: Camaro
Engine: 305 TBI
Re: blower motor
Lou
I found out that the smell is coming from behind the AC control panel along with smoke.
Old May 15, 2009 | 11:36 AM
BigBadLou's Avatar
Engine: TPI
Re: blower motor
That is not good. In that case, I recommend pulling the HVAC panel out to see what is creating the smoke and smell. The last thing you want right now is your car catching on fire.
Lou
Frozer!!!
Jan 19, 2024 04:55 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
zayne0
Aug 24, 2015 07:22 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
