Fuel Pump Wiring
Old May 9, 2009 | 02:58 PM
HAWAIIFISH's Avatar
Fuel Pump Wiring
I just purchased the 87 about months ago. So I need to know what wire from inside the engine needs to be hot in order for my fuel pump to properly work. I dont have a problem with the pump itself but in stead of being wired correctly it is bypassed now. I want to correct the original problem which is supposibly a fusable link gone bad. Since I do not have access to the fuel pump I only have one side to work from. The engine side. Any suggestions
Old May 9, 2009 | 04:55 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Fuel Pump Wiring
You dont need two threads for the same question, esp not in the same forum
Simplified, it is this:
Ignore the note and the enable pin label, this was for a LS1 pcm swap
Old May 10, 2009 | 11:04 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Do you still have the fuel pump relay socket? It has an orange wire on it, that's the one you need to trace. It travels through the engine harness loom to the fenderwell next to the battery to a single fuse holder. That fuse powers your fuel pump and also the ECM.
That orange wire should be easy to identify in the harness (not many wires like that in the loom), especially since you can probe it with the fuse in and out and see whether the wire has 12V on it or not.
Hope this helps.
Lou
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
