headlights
Old May 16, 2009 | 06:41 AM
pontiacsteve's Avatar
Car: 82 z28
Transmission: auto th350
Axle/Gears: stock
headlights
on high beam 3 headlights work and on low, none work. I just want to know if one bulb being burned out has any affect on the other or if there is a wiring problem. I believe the outside lights are the high beams(3)prongs they work and one (2) prong inside works while on high beam. thanks
Old May 16, 2009 | 06:51 AM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
Re: headlights
your inside lights should be the high beams. i am having a similiar problem.
Old May 16, 2009 | 09:05 AM
Car: 82 z28
Axle/Gears: stock
Re: headlights
Now that you say that ,I know you are right about the high beams are the inside lights. The car has sat for years and I suppose the low side elements could be burned out.Thanks for the insight,now I have some checking to do.
Old May 16, 2009 | 09:57 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: headlights
Actually, there are high beam elements in both sets of lights. The inner pair are high beam only. The outer pair are your lows and also have a high beam element in them. When the high beams are on, all 4 lights should be on. With the low beams, only the outer 2 should be lit. Sounds like you've got some lights that need replacing.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
