No power steering connector on harness???
Old May 26, 2009 | 09:54 AM
amichals's Avatar
I was wondering why my 89 Camaro 350 TPI harness had no power steering wire connector on it. I opened up the harness in 2 different spots and there is no sign that the wire that connects to the power steering was there. Is this wire located somewhere else on these cars. Please help because driving with no power steering really sucks. Thanks.
Old May 26, 2009 | 09:56 AM
amichals's Avatar
Re: No power steering connector on harness???
I also wanted to know if there is a way that I can hook this wire up myself. Can I just connect it to a hot in run only wire on the vehicle or does it have a specific location?
Old May 26, 2009 | 02:06 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
TPI engines don't use the power steering pressure switch, if that's what you are asking about.
What do you mean by "driving with no power steering really sucks"? Power steering does not require any electricity, only a running pump.
Lou
Old May 31, 2009 | 08:29 PM
nitemare70's Avatar
Car: 83 Z28
Engine: Comp Controled 350 w/ carb
Transmission: 5 Speed
Wait a minute...power steering pressure switch? What is this and what is it for? I have 83 Z that is HARD to steer at low to no speed. Plenty of fluid, belt on and tight, was thinking pump bad or steering box bad. It does not squeal when steering wheel turned. I did not know of an electrical component.
Old May 31, 2009 | 08:39 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
The switch has nothing to do with the actual function of the power steering, to the best of my knowledge it just throws a CEL if the fluid or pressure is low.
Old May 31, 2009 | 08:59 PM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
The connector is there on the V6 or Iron Dukes... it adjusted the idle when not moving and steering...
Old May 31, 2009 | 10:55 PM
BigBadLou's Avatar
Engine: TPI
Correct, WhiteBlaze.
Also, they put it on the VIN E engines (TBI) since they are considered weak at idle. As pointed out, the switch allows the ECM to add fuel to prevent engine stalling at idle when an idiot driver holds the steering wheel in lock.
Lou
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
evilstuie
Apr 14, 2016 08:52 PM
