Dash Pinouts / Fuel pump wires
Old May 28, 2009 | 11:41 AM
HonkyTonkMan's Avatar
I have a 86 Camaro z28,
In wich i have removed the complete engine harness and replaced engine and transmission. (GM zz383 / Tremec tko600,)
And i have installed a Holley Stealth Ram injection kit.
I am also replacing the original dash with a dakota digital unit.
so. the problem is
Does anyone have the pinouts for the dash connectors ? I need the tank sender unit wires, and the tach one. I have read the pinned post on the electrical wiring, but cant find these anywhere.
And where do i find the fuel pump relay ?
Old May 28, 2009 | 12:38 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Dash Pinouts / Fuel pump wires
http://92b4crs.tripod.com/86wiring/86wiringindex.html
Fuel pump relay should be next to the brake booster on the firewall.
Old May 28, 2009 | 05:00 PM
Thanks alot.. e knew i have seen it somwhere... ;P =) =) =)
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
