switch from automatic to manual
Old Jun 1, 2009 | 12:09 AM
mrfiles's Avatar
Car: 87 z28 tpi and 06 cobalt
Engine: 305 ho tpi and 2.2l ecotec
Transmission: 700r4 and not a clue
I recently switched my 87 camaro from auto matic 305 tpi to manual 350 carb. i have a promblem of course. There is 6 wires that went into my automatic shifter on the side for the safety switch so the car couldnt be started unless it was in neutral or park can anyone tell me what wires i need to run to the clutch switch so i dont have to have both shifters in the car to start it thanks .
Old Jun 1, 2009 | 07:24 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: switch from automatic to manual
There are two big fat wires on one side of the plug, those are the two that go to the neutral safety switch. I think they're purple and green on my car, but I'm not positive. But they're hefty friggin wires. Probably 10 gauge.
Old Jun 1, 2009 | 10:47 AM
mrfiles's Avatar
thanks a lot i appreciate the help
Old Jun 1, 2009 | 09:17 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
The wires are purple and yellow. However, if you look hard enough under the dash, you might just find a connector under there that was put there at the factory but left unused (because your car didn't have the clutch switch).
Also, you need to run the light green and the blue wires (on the neutral safety switch) down to the reverse light switch on the side of the transmission so you have working back up lights.
Old Jun 1, 2009 | 10:58 PM
mrfiles's Avatar
thanks i appreciate all the help
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
89GTAOz
May 16, 2020 09:31 AM
Vintageracer
Jan 10, 2020 05:33 PM
camaro11j
Sep 19, 2018 08:49 AM
