"Security Switch" - Coil wire ok?
Old Jun 2, 2009 | 11:53 AM
Chuck's Avatar
Will this have a negative effect on engine performance?
To install a "security switch":
1 -Cut one of the wires from coil to distributor.
2 -Splice in wiring to switch under dash.
Just wondering if extra run of wiring will somehow bother
the ignition.
Also, someone said to use "shielded wire" and ground the
"shielding". What gage wire would you suggest?
Thanks!
Old Jun 2, 2009 | 12:42 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
CALL SECURITY
Don’t do that.
It’s high voltage therefore the machinations you would have to go thru would be elaborate.
You can accomplish the same thing by cutting the 12 volt feed going to the module in the distributor.
Use a size larger than you see to avoid voltage drop.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. Turn em off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
Old Jun 9, 2009 | 09:13 AM
NINÅ's Avatar
Transmission: 765R4
CALL SECURITY
Got your e-mail Chuck.
I don’t know the color however you can cut one of the wires coming from the 2 pin portion of the module connector.
They go to primary of the coil.
No need to open the distributor.
Do it at the coil.
Happy Racing!
stalkier
Dec 6, 2015 11:25 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Tonyy_z
Aug 12, 2015 07:20 AM
L98GTA87
Aug 5, 2015 11:02 PM
