Reverse lights help
Old Jun 6, 2009 | 09:24 AM
rocketforme's Avatar
Car: 1989 GTA
Engine: 350 tpi
Reverse lights help
I recently replaced my neutral safety switch and my reverse lights worked. Then the following weekend when I took it out my wife noticed they did not work again. The reverse blinked but did not stay on while I was backing up. Any ideas why I'm having problems?
Old Jun 6, 2009 | 11:57 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Reverse lights help
I'd doublecheck the switch on the shifter and its adjustment (if you have an adjustable switch - I'm not sure, I'm not an automatic guy). Because the switch is the only thing that controls your reverse lights.
The lights are powered from the turn signal fuse so if your turn signals work, the shifter switch should have power on it.
If you'd like to troubleshoot it with a test light, look for the blue wire and green wire (both thin).
Hope this helps.
Lou
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Jetmeck
Sep 4, 2015 12:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
