HEI distributor on stock motor????
Old Jun 10, 2009 | 07:23 AM
mos68x's Avatar
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
Does anyone know if there is enough clearance off the firewall to put in a HEI coil cap distributor? I have one from MSD from a few months ago and have never put it in since it really looks next to near impossible to get it in there. I do plan on taking the TBI inake off and replacing it with a carb one so if I can be sure that I'll have the room to install the distributor I'll put everything on. Otherwise I'll have to take this one back and find one that will work for what I want - a one wire setup.
Leon
Old Jun 10, 2009 | 02:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: HEI distributor on stock motor????
Lots of these cars came with coil-in-cap distributors from the factory.
Old Jun 10, 2009 | 02:26 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
in other words: Yes it will fit.
Old Jun 10, 2009 | 09:23 PM
mos68x's Avatar
That's what I thought, but there just doesn't look like much room there.
Next question then...how do I get the thing in there? The firewall shrouds the distributor pretty good. Do I have to lift on the back of the trans to get the motor to lean forward enough to drop it in?? That's really the only thing I can think of...and yes I did check the Haynes manual, it shows the motor already out of the car.
Old Jun 10, 2009 | 11:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Take the cap off when you put it in, and tilt it forward a little to clear the cowl. There's lots of room.
Old Jun 11, 2009 | 06:07 PM
mos68x's Avatar
Ok, I didn't think it would have been that easy with the way it looks. Guess I asked a stupid question. Thanks for the replies, now to find the money to buy a carburetor.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
midge54
Jan 29, 2017 07:00 PM
midias
Aug 15, 2015 05:07 PM
stalkier
Aug 7, 2015 04:49 AM
