Having Tach Problems!!!!
Old Jun 8, 2009 | 09:00 AM
Heitz86's Avatar
I have a 91' camaro RS wit a carb 305, also running off a msd 6T, I just installed a tach in the car but it wont read right, the car will be idle at 1000 rpms but the tach will read about 6000 rpms, I know its not the tach tho cuz this is the second one, the first one did the same thing so I trashed it, only to find out it was probably fine. its wired up the right way I just dont know why it would read off like that........ anyone got any ideas????
Old Jun 8, 2009 | 07:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Having Tach Problems!!!!
By the right way, you mean that the tach is connected to the tach terminal on the box?
Old Jun 8, 2009 | 08:07 PM
dwight21's Avatar
what brand of tach is it and did u ckeck the wires on the back ? u may have wired it up for 4 or 6. that may be our problem.
Old Jun 9, 2009 | 06:05 AM
Heitz86's Avatar
its a mac tools racing that is only for 8 its not adjustable....... :/
Old Jun 9, 2009 | 06:16 AM
Heitz86's Avatar
the tach is wired to one of the wires going from the msd to the coil, the orange one to be exact. im not to sure i know what you mean about the tach terminal, this is the first time i have ever messed with wiring
Old Jun 9, 2009 | 01:39 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's not the right way, you can't put the tach on the coil primary with an MSD box. At low RPM it's firing 5 times per cylinder, so your tach will read 5 times higher than the engine is really running. The box has a a separate terminal just for driving the tach, check your installation manual.
Old Jun 10, 2009 | 10:33 PM
dwight21's Avatar
i agree with apeiron he has a good piont
Old Jun 12, 2009 | 07:24 AM
Heitz86's Avatar
Thanks guys, working great now, I thought I had it right cuz I was using the tach installation manuall for a stock car with out the msd. I really appreciate your guys help.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
