Rear Hatch Wont Shut
Old Jun 16, 2009 | 07:41 PM
Eustace16's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
My rear hatch wont shut on my 89 Camaro
i cant hear the motor when i try to close it, it just will not click
please help fast i cant driveeeeeeeeee
Old Jun 16, 2009 | 09:01 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Re: Rear Hatch Wont Shut
Is the motor running but the latch doesn't pull down? If that's the case you probably have a stripped or broken gear in your motor assembly. You may only need a new gear but if you need a complete motor assembly we have them available on our site.
Old Jun 17, 2009 | 03:16 AM
G Money's Avatar
Car: '87 IROC (blue)
Transmission: borg warner 5 sp
my hatch motor works sometimes but i have to bypass most of the time. should i wire a remote bypass switch by my seat or do you have a solution?
Old Jun 17, 2009 | 11:18 PM
Schwinny's Avatar
Car: 1987 Firebird
Engine: 2.8l V6
Take the "ACC" wire out of your radio and run it back.
It only comes on when the key is on.
Call me crazy, but it just may work.
Old Jun 17, 2009 | 11:45 PM
Stephen's Avatar
Car: 87 GTA
Is the latch stuck closed? Or is the motor not pulling the down, to reach the latch?
If the motor is down, you can unplug it to leave it down & just use the key to open the latch.
If the motor is stuck UP, you can get it down manually, unplug it, then use the key.
Either way, that'll get you moving again.
Old Jun 18, 2009 | 02:29 PM
Eustace16's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
The hatch just does not close....no motor noise and it does not lock down, when i push it down it just fly's right back up.
Old Jun 18, 2009 | 02:33 PM
Stephen's Avatar
Car: 87 GTA
Have you physically unlocked it, from the back, with your key?
It is sounding like the latch is simply closed. Unlock it with your key & see if it'll close then.
Old Jun 18, 2009 | 02:35 PM
Eustace16's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
I tried using the key to lock it and it just opens right back up so the key hole behind the license plate only opens the latch
Old Jun 18, 2009 | 02:40 PM
Stephen's Avatar
Car: 87 GTA
From your descriptions, I can't tell if your pull down motor is working,if the latch isn't working, or both.
But it is SOUNDING like a latch problem, not a motor problem, huh?
Old Jun 18, 2009 | 07:16 PM
G Money's Avatar
great idea cause i already have acc wire to my amps in the well back there. willm try it and let you know how it works out.
thanx
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
