IAC/TPS Question!
Old Jun 20, 2009 | 11:36 AM
MI ROC-Z's Avatar
Car: 89 IROC-Z
Engine: L98 5.7 liter
Transmission: TH700r4
Axle/Gears: limited slip 3.23
IAC/TPS Question!
Has anyone ever heard of or experienced a problem with either the TPS or IAC that could cause a battery drain within 6-7 days?
My problem is this... The other day after I drove the IROC I parked it and went out the next day to take a multimeter reading of the battery amps. While taking the reading I noticed a clicking/scratchlike sound (almost like a data logging noise) coming from the area where the IAC/TPS sensors are. So I disconnected the TPS and have been taking readings with the multimeter to determine if I found the source of my battery drain.
Im kind of at wits end with this battery drain as it has been an ongoing issue since I got the car and hope somebody will be able to shed some light on the problem.
Thanks for any and all help.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
