MSD Blaster 3 Coil Compatible??
Car: 92 RS
Engine: 305 TBI
Axle/Gears: 4th Gen/3.23/Posi
Hey guys - I've been searching on this for well over the past hour and haven't seen many people referencing doing this with a relatively stock setup. I have a new Blaster 3 coil laying around, and I was Considering using this instead of the typical external coil used on a small-cap dist.
Initially I thought it was a no-go since the external coils have 2x 2-plug connectors on them. But then when I found the wiring schematics here:
https://www.thirdgen.org/forums/alte...r-wireing.html
...on post 7, it appears that the 2 are just being wired in line with each other, essentially just being 2 wires to the coil, but headed in two directions.
Would it be the same setup to wire pink to + and white to - ? Am I misreading the diagram...not understanding something completely... or should that work?
Car: 92 RS
Engine: 305 TBI
Re: MSD Blaster 3 Coil Compatible??
No one has experience running a standard external coil on these things?!
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
