Wiring Harness help!!
Old Jun 28, 2009 | 07:17 PM
Waymores's Avatar
Car: 89 Camaro
Engine: 350 TBI
Ok 305tbi to 350tbi swap, when we were pulling the motor, we labeled everything from the harness with tape... with cheap dollar general tape.. anyways, some of the tape came off during the process, and there are some conncectors that arent plugged in. I was wondering if there is a website that had a detailed diagram (i cant make heads from tails from the schematic charts), or something with pictures of the male/female ends of the connectors that may explain where they go, or what they do. If that makes any sense. If not, i dont have any pictures of these connectors, but ill try and describe them. They are all on the drivers side
The 1st one is a square shaped connector, male end, and has 4 yellow ish cylinder shaped, maybe an inch long prongs/tube looking.
On the same line of wires is an oval shaped connector, female, grey in color with about 6 or so openings, its about the same size and shape as the ignition control connector in distributor.
Any help would be greatly appreciated, thanks
Old Jun 28, 2009 | 09:32 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Re: Wiring Harness help!!
A picture of the plug(s) would be great or wire colors. Drivers side of motor has Oil pressure sensor by the oil filter and in the same harness a little longer is the temp sensor in the head between #1 and #3. Good luck. I have before and after pictures of my motors when I did this swap that I used to put all of the sensors back in the proper places. If this would help you, P.m. me and I will e-mail them to you.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
