Shifter Switch Wiring "HELP NEEDED"
Old Jul 8, 2009 | 02:14 PM
94Pontiac's Avatar
Car: 1988 Chevrolet Camaro IROC-Z
Engine: 350 Tuned-Port Injection
Transmission: 700 R4
Axle/Gears: 3:73
Hi, recently purchased an 88 IROC with a 5.7 TPI, i700r trans, it has a B&M Shifter (don't know what kind), the problem is the car starts in drive and reverse, (it starts everywhere,) I got the correct switches on the shifter from B&M I replaced them as a place to start, however they old ones were ok, I still have the problem, I don't have any thing (schematic) to check the wiring against to see if it's wired properly. There seems to be a factory switch or relay or whatever that purple and yellow wires go into.
I'm replacing that as well because when I moved it around to inspect it a connector tab broke off where a yellow wire goes in. Anyone that can help with wiring or tell me where the wires on the 2 switches on shifter should go will be my hero, thanks
Old Jul 9, 2009 | 11:46 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Use an ohmmeter to determine if the new start lockout switch is aligned.
Original wire colors which go to the lockout are purple and tan/white.
When those 2 wires are connected you can start the car.
If you can still start in gear you will have to troubleshoot/un-alter it.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look dorky. Turn em off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
Old Jul 9, 2009 | 09:32 PM
Billy_Bob's Avatar
Car: 92 GMC Sierra 2500
Engine: 5.7l
Transmission: 4L70
Axle/Gears: GT4 3.73
Re: Shifter Switch Wiring "HELP NEEDED"
You can order a factory service manual set from your dealer or from here...
http://www.helminc.com
A 99 set I have has about 3000 pages (4 big books) of detailed, troubleshooting instructions, wiring diagrams, DTC codes, part replacement instructions, etc. And all for one specific year and type of vehicle!
Old Jul 10, 2009 | 01:43 PM
94Pontiac's Avatar
Axle/Gears: 3:73
thanks for your info I'll try it
1992 Trans Am
May 10, 2023 07:19 PM
89GTAOz
May 16, 2020 09:31 AM
NBrehm
Aug 25, 2015 11:49 PM
Dialed_In
Aug 20, 2015 01:45 PM
355sbcTPI
Aug 19, 2015 04:38 PM
