Power Lock Problem
Old Jul 14, 2009 | 03:17 PM
mmm88TA's Avatar
Engine: 5.0 TPI
Transmission: TH700R4
Axle/Gears: 3.43 posi
Power Lock Problem
I haven't been driving my car much this summer and when I was in it yesterday the power locks started clicking by themselves. I assumed it was a short somewhere. I pulled the PWR ACC fuse 30Amp (BTW my chilton's says its supposed to be 35A) anyway it seems like the only things on that fuse are the pwr door locks and the radio. I pulled the radio and checked the ground which was good, I tried the locks w/o the fuse and still got clicks from the relay. I then put the fuse back and the locks cont. to lock/unlock on there own. Then I pulled the kick panel and checked the relay, it had 2 wires piggybacked on it from what I assume was the PO's alarm system. I removed them and now the locks don't work at all. I've had this car for roughly 8yrs and never had any wiring problems. Could it just be a bad relay causing this and wheres a good place to pick one up besides the JY? BTW the car is a 1988 trans am
Old Jul 15, 2009 | 03:10 PM
mmm88TA's Avatar
Engine: 5.0 TPI
Re: Power Lock Problem
BUMP any ideas?
Old Jul 16, 2009 | 08:47 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
LOCK SHOCK
Check to find out where the PO removed the connection(s) that should be there, and added connections that should not.
The fuse needs to feed the lock switches.
The switches need to feed the relay coils.
The relay contacts need to feed the door locks.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look dorky. Turn em off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Bert87
Aug 23, 2015 03:50 PM
