MSD Ignition
Old Jul 14, 2009 | 06:24 PM
duey_roc's Avatar
Car: 87 Pontiac Trans Am GTA
Engine: 5.7 350 V8
Transmission: Automatic
Axle/Gears: ???
MSD Ignition
What does an aftermarket ignition do performance wise?
Old Jul 16, 2009 | 10:27 PM
gheatly's Avatar
Car: 1982 Z-28
Engine: 5.7L Crossfire
Transmission: TH-350
Axle/Gears: GM Posi, 3.73
Re: MSD Ignition
Well, most modified, carbureted engines run a tad rich. An MSD will keep the plugs cleaner than a stock ignition. Other than that, not sure if one is needed on a mildly modified engine. They are used in racing to keep the plug firing under boost, with nitrous, or with high compression ratios. In those cases, you need a more powerful spark to jump the plug gap.
Supposed benefit on a stock motor is that you can run a wider plug gap, exposing more of the spark to the A/F mixture. This, and the fact that an MSD shoots out multiple sparks below 3000 RPM, decreases the likelyhood of a misfire.
One of the rags did an aftermarket ignition test within the last year or two and found minimal HP/TQ gains. However, they noted that the engines ran smoother with a high energy ignition. This is likely from reduced misfires. I have noted this on my engines as well. I have a 6AL on my 82 CFI car.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
meeklay812
Oct 1, 2015 03:46 PM
RedLeader289
Sep 23, 2015 06:50 AM
