manual fan switch & stock fan control
Old Jul 23, 2009 | 10:02 AM
gta007's Avatar
Car: 89 FORMULA 350 / 1991 RX7
Engine: 5.7 L98 / LT1
Transmission: 700R4 / 6 speed manual
Axle/Gears: 3.42 posi / 4.11 posi
Hi guys
i have a 89 gta 5.7 with dual fans. The fans kick on like there suppose to, but i would like to have the choice to control both manually. I am interested in installing a manual fan switch. However i would also like for my car to operate as gm intended. What is the easiest way to add a manual fan switch, for BOTH fans? I have been studying the chilton, & chevy thunder wiring diagrams. I would like to tap into the wire as close to the ecm as possible. Is C1, or E8 the wires I need to tap? any help would be great. btw I don't even see C1 on my chilton diagram.
Old Jul 23, 2009 | 02:09 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Re: manual fan switch & stock fan control
I have no idea what pin at the ECM you would need, but you'd want to find the connection for the A/C wire that controls the fans - the second fan only comes on with the A/C as I understand it, and therefore BOTH fans would operate if the system was "fooled" into thinking (with your switch) that the A/C was on, whether or not it actually is on. I know on my single fan 1992 car, there is a green/white wire running to the A/C compressor that actuates my single fan whenever the A/C is actually on.
Hope that helps some.
Old Jul 23, 2009 | 09:15 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Since you have two relays that controls two fans, you'd need a Dual-Pole (DPST) switch that can turn on both relays, by grounding them. You'd need to ground E8 and D11, separately.
I would advise against grounding the A/C input on the ECM (B8) because that would make the ECM increase the RPMs for the A/C to kick in.
Hope this helps.
Lou
Old Aug 14, 2009 | 09:18 PM
KRUSS's Avatar
Car: 1992 Arctic White Z28 Convertible
Engine: LB9 305 cid TPI
Transmission: 4L60
Axle/Gears: B-W 7.75" 3.73
Dual fan control that DOES NOT disable factory fan setup. It works great...
https://www.thirdgen.org/forums/elec...en-3647-a.html
Old Aug 15, 2009 | 09:50 AM
Pocket's Avatar
Car: 91 Trans Am
Hope this helps.
Lou
Agreed
The ECM grounds the relays to engage the fans. T into the ECM wires (should be dk grn/wht stripe) and ground them via switch and you should work
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
dhonda200
Aug 11, 2015 11:50 PM
