please help, oil pressure and coolant temp.
Old Jul 25, 2009 | 02:51 PM
crash17's Avatar
Car: 92 camaro
hi
i just did a swap from a the 3.1 to a carb'd v8 in my 92 camaro. i have the car running and driving but when i tried to get the oil pressure gauge and water temp. gauge to work they wont. i used the oil pressure gauge that come off the v6 and just extended the wire length to fit and a water temp sensor was already on the engine so i just cut the connection off for the v6 harness and that didn't work so i reinstalled the stock connection and installed the sensor (off the v6) to my v8 and still nothing. any advice?
Old Jul 25, 2009 | 05:11 PM
crash17's Avatar
Car: 92 camaro
Re: please help, oil pressure and coolant temp.
no one knows?
Old Jul 26, 2009 | 11:38 AM
rich14's Avatar
I done the same thing before only we used the sensor off an older style v-8. If it don't work and you know it did before maybe a ground? is it a regular cluster or digital?
can you tell me what color the wires your hooking up are? There is the ones for the gauges and the ones for the lights.
Old Jul 26, 2009 | 01:31 PM
crash17's Avatar
Car: 92 camaro
i don't know why i didn't think of the idot lights. i don't remeber the colors off the top of my head but i believe for the oil pressure it was a white/light tan, brown, and a orange. the sensor i used (along with the wires/connection from harness) came off the oil filter plate. the coolant temp was a single wire, maybe yellow, but that sensor and connection came off the right side of engine just above the starter. i was sure to hook up the same sensor and connector that was stock on the car.
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
solocus
Sep 2, 2015 12:14 PM
CamaroGuy350
Aug 30, 2015 02:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
