Both headlights quit working at the same time...
Old Jul 29, 2009 | 06:07 PM
LibRat72's Avatar
Hi. I put a new front clip on my 91 Firebird some time ago. The headlight both raised and lowered fine on the other car and worked fine on my car. For a while. One night I turned the lights on, they raised up and never went back down. I have to manually raise and lower. Any ideas why they both quit working at the same time? I have run out of guesses. Thank you in advance
Old Jul 30, 2009 | 10:01 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Both headlights quit working at the same time...
There's a big flat black box on the firewall, next to the wiper motor. It has two connectors on it. That's the headlight motor module. Try tapping on it with a screwdriver while turning your lights on and off. It could be just a bad contact.
If that doesn't help, you'd need to break out the test light and probe some of the wires on the connectors.
Let us know.
Lou
Old Jul 31, 2009 | 09:03 AM
1Aauto's Avatar
Former Sponsor
Welcome to the site. I test as described above.Let us know how yah make out.
Old Jul 31, 2009 | 11:12 PM
Pocket's Avatar
Car: 91 Trans Am
You said you put a new front clip on. That means alot of things got removed and bolted back up
Check your grounds. There should be two behind the headlights along the radiator support
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
stalkier
Aug 13, 2015 12:59 PM
92camaroJoe
Aug 13, 2015 06:07 AM
