fuel pump problems
Old Jul 30, 2009 | 09:30 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
fuel pump problems
So my fuel pump went out the other day and the shop I go to said it was gonna cost $500 for the job. A guy I know (ASE and Michigan certified) said he'd do it for barley over the cost of parts so I let him do it.
I got the car back yesterday and there is this loud whine coming from the rear end, I assume it's the pump since i messed with the exhaust and other stuff back there and nothing made a difference. Plus my gas gauge always reads well above full even though I've driven 100 miles since I got the car back with less than a full tank. I took the cluster apart today and pushed the needle down but upon starting the car again it went right back up as far as it could.
I don't know if these 2 problems could be related or not. Maybe just let it go for a while and see if it gets better? I dunno?
Old Jul 31, 2009 | 09:24 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: fuel pump problems
These two problems could be very well related.
The fuel gauge shares the same wiring harness as the fuel pump. Your friend might have accidentaly disconnected/cut the fuel sender wire (pink) by the fuel tank, causing the gauge to read Full (it reads full when there is a break in the circuit).
Lou
Old Jul 31, 2009 | 09:31 AM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
He told me since the pump was a newer style he'd have to rewire it... It came with a little harness and stuff to do this. I'm not sure I see how having that wire cut could make this noise, could you please explain. And what will I need to do to fix it?
Old Jul 31, 2009 | 10:55 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
what kind of pump did he put in? some make noise - a lot of noise.
Old Jul 31, 2009 | 12:42 PM
BigBadLou's Avatar
Engine: TPI
Also, if he put in an external pump, it's outside of the tank now and the noise is not muffled by the tank or its contents. That would add to the noise level as well.
Lou
Old Jul 31, 2009 | 02:56 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
well, i know somethings wrong now. When I was driving downtown i hit a stoplight. when it turned green I puth the pedal down pretty good. It reved up to 2K then went down to 1500 and wouldnt go any higher. I let off a little and it returned to 2K as I went towards home it onlt got worse. By the time I got home if I gave it any gas the rpms would drop and the car start to die.
So basicy its almost doing the same thing it was before the new pump...
Old Jul 31, 2009 | 03:37 PM
BigBadLou's Avatar
Engine: TPI
Which begs the question: how did you determine the first time that your fuel pump was bad?
Time to put a fuel pressure gauge on the fuel rail to see how much you're building up.
Lou
Old Jul 31, 2009 | 11:22 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
I had the shop diagnose it, didn't charge me for it. Just had a new regualtor put in last year so I don't know how that coulkd be bad. followed both fuel lines down the frame and to the injectors, didnt see any pinches.
I drove the car again tonight and it was fine when i left but when I got to my destination it has acting up again, same thing on the way home. It runs good for a miles then starts to act like its not getting enough fuel..
Old Aug 1, 2009 | 12:01 AM
BigBadLou's Avatar
Engine: TPI
I say again, put a gauge on the fuel rail to see what is really going on. Something tells me you'll find out real quick.
A shop can say you need a new fuel pump (gives them a $500 job) but don't ask me how many times I've seen shops give out false diagnosis just to make some money.
Lou
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
