who can tell me what these are
Old Aug 3, 2009 | 10:35 PM
t0astm0nkey's Avatar
Car: 1984 Trans Am
Transmission: 4L60e
I trying to figure out what the relay on the left is and that the heck the thing with the vacuum line is, it has wiring on it, and i want to know if it is neededName:  P8030001.jpg
Old Aug 4, 2009 | 03:36 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: who can tell me what these are
unplug it and find out!
Old Aug 4, 2009 | 07:09 AM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
what type of car is this ?
Old Aug 4, 2009 | 07:43 AM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
the vacum thing looks like part of the 700r4 lockup kit i had in my s-10. when hooked up right. would only allow lockup with 4th gear and part throttle.
Old Aug 4, 2009 | 09:23 AM
Car: 1984 Trans Am
Transmission: 4L60e
this is my 1984 trans am, and A, unplugging it may not do anything, and b, it is not the lock-up, i have a 4l60e
Old Aug 4, 2009 | 09:33 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Given the colors of the wires, I'm wondering if the relay is the relay from the fuel pump - but 1984 might not had an in-tank electrical pump - I'm not that familiar with the older models. The vacuum switch might have ben TC lockup BEFORE you swapped to the 4L60e - I can't think of anything else that would have a vacuum switch on it like that.
Old Aug 4, 2009 | 11:05 AM
Car: 1984 Trans Am
Transmission: 4L60e
i figured out that the one with the vacuum only had 1 wire left hooked up, so i decided it couldnt possibly be too important... the relay was for the radiator fan....
but what the F is this?? i was hooked up to the vacuum line that i just removed, its right above the master cylinder and brake booster Name:  P8040001.jpg
Old Aug 4, 2009 | 06:30 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
That vac line looks like the one that goes down to by where my washer fluid reservoir is. I think it went all the way around the back of the firewall over to a t that t's off to intake and the mass air doohicky. Yes, that's right. I said doohicky.
Old Aug 18, 2009 | 12:49 AM
Car: 1984 Trans Am
Transmission: 4L60e
found two electronic on the interior... what are these, under the passenger side kick panel, near the old ecm, anyone know what they are??
the first: Name:  fd05bb39e503__1250532407000.jpg
and the second.. is cirlced, a relay maybe??
Old Aug 18, 2009 | 08:44 PM
Pocket's Avatar
Car: 91 Trans Am
In the first few pics, its hard to tell what a relay does with little info on the car
Since the swap is already in there, it makes things more difficult to deduce. Get a multimeter and trace the circuits
The thing over the booster looks like a vacuum reserve
The box thing, trace the wires and find out
The silver thing circled in red is the rear defroster resistor thingy. You need it for a functional rear defroster
