electrical gremlin (radio and hatch)
Old Aug 4, 2009 | 08:37 AM
Raato's Avatar
Car: 88 IROC
I was hoping to get a little assistance here. My radio, power antenea, rear hatch and power locks release dont work all the sudden. Dash lights, windows , headlights and wipers work fine. I already checked the fuses and they all look good.
Currently the radio has no display, I would assume due to no power, but when I power it up you can hear the power to the speakers(slight hum). The rear release I cant hear anything same with door locks.
Would this possibly be a bad ground? if it is how can I go about finding it?
Please keep it simple I am pretty green with electical stuff. BTW this is an 88 IROC 305TPI in case it matters.
Old Aug 4, 2009 | 10:16 PM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: electrical gremlin (radio and hatch)
Looking at a fuse is not a reliable way to check a fuse. Pull the fuse and use an ohmmeter. If you get 0 ohms the fuse is good. If you get a high reading near the top of the ohmmeter scale the fuse is bad. Some fuses also have a small open slot on each side.
[/quote]Currently the radio has no display, I would assume due to no power, but when I power it up you can hear the power to the speakers(slight hum). The rear release I cant hear anything same with door locks.
Please keep it simple I am pretty green with electical stuff. BTW this is an 88 IROC 305TPI in case it matters.[/quote]
All of the items you listed receive power from the CTSY fuse for the relay functions. The radio has a separate fuse to power the radio. However, both the radio display and the power antenna get power from the CTSY fuse. The Power Locks release relay also receives power from the CTSY fuse. The locks themselves receive power from a circuit breaker mounted on the fuse block.
The common theme for all the non operable itmes is the CTSY fuse. If you don't have an ohmmeter just buy a new fuse and put it in. If you put a new fuse in and the accessories still don't work, check that fuse also. If it has blown you have a short circuit in the wiring.
Let us know what happens when you test or replace the fuse.
1992Z28!
Nov 19, 2015 07:33 AM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
Johnoooooo
Sep 22, 2015 08:55 AM
