need help with harnesses
Old Aug 5, 2009 | 07:16 PM
mg8100's Avatar
Car: 82 camaro z28 cross fire injection
Engine: 305 v8
my rear parking lights and backup lights dont work i think a rat chewed through the wire somewere, i was wondering if i need to get the whole chassis harness or just the body harness
chassi harness :
http://www.autopartswarehouse.com/sk...%26+Drivetrain
body harness:
obviously the body harness is way cheaper but i dont know if that is what i need. any help would be appreciated.
Old Aug 5, 2009 | 11:17 PM
mg8100's Avatar
Engine: 305 v8
Re: need help with harnesses
bump?
Old Aug 6, 2009 | 01:55 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
If you can where the rodents chewed the wires, post-up a couple photos.I found a yard that has a few 3rd gens. I could get the harness from there unless you want to re-do with Painless. That's a good company.
Old Aug 6, 2009 | 10:45 AM
mg8100's Avatar
Engine: 305 v8
the problem is i dont know were they chewed threw the wires, and i dont have time for the repair myself so i figured it would be cheaper to get a new harness and have it installed instead of pay them to try and troubleshoot till they found it. i just dont know which harness i need to get.
Old Aug 7, 2009 | 08:21 AM
Pocket's Avatar
Car: 91 Trans Am
There is alot of harness and connections in between the backup switch and brake switch and the actual tail lights
Get a multimeter and narrow down the circuit
It maybe as simple as a broken/loose ground or blown bulbs
Old Aug 8, 2009 | 09:13 PM
Car: '87 Camaro
The prob I had was some one put a taillight harness from a Firebird,AND they cut out some wires!! I was GREATLY helped by some VERY patient TGO members. I ended up getting the correct harness. Wish you luck & hope you're driving soon.
92firebirdchris
Exterior Parts Wanted
Oct 1, 2015 01:38 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
z28joe2
Sep 28, 2015 05:54 PM
Eric-86sc
Sep 28, 2015 11:37 AM
efiguy
Sep 27, 2015 01:30 PM
