Passenger side blinker stays solid
Old Aug 11, 2009 | 12:02 PM
sr20fd3st's Avatar
Car: 84 Z28, 68K Miles
Engine: 10.5 Compression 350
Axle/Gears: 3.83
Hi. Have been rewring alot of things including engine and light harnesses.
just a few days ago both blinkers worked just fine. havnt done anything since then (i think) and now the driver side blinks fine, but the passenger side just stays on without blinkage
im stumped. have been sifting through wiring diagram pages for a while.
any help would be awesome
-Oliver
Old Aug 11, 2009 | 12:15 PM
Stephen's Avatar
Car: 87 GTA
Re: Passenger side blinker stays solid
Check all the bulbs. That is the typical notice to the driver, that a bulb is blown somewhere.
Old Aug 11, 2009 | 08:30 PM
iroc_patron's Avatar
Possibly a missing connection to ground? I was rebuilding my hatch pull down the other day and didn't reconnect a ground and my turn signals didn't blink, but I think it was both sides in my case. Just an idea.
Old Aug 12, 2009 | 11:22 AM
sr20fd3st's Avatar
Axle/Gears: 3.83
All the blulbs work. I'll check all the grounds again though, thanks.
ALSO: When I turn the interior lights on, the 2 dash blinker indicator bulbs light up too. Again...clueless.
Old Sep 16, 2009 | 07:15 AM
sr20fd3st's Avatar
Axle/Gears: 3.83
Still havn't been able to solve this. When I give the flasher module a good smack, the right blinkers will blink once. The left blinkers have no problems. I don't understand, since the current goes from the blinker switch into the flasher, then to the lights, how the drivers side bulbs blink but the passenger ones do not. They share the same damn flasher. Why will it blink for one side and not the other?
the flasher itself works...and the current to the bulbs when you hit the blinker switch can only get to the bulbs by going THROUGH the flasher.
I know they use a separate flasher, but the hazards work just fine by the way...
so stumped
Old Nov 29, 2011 | 12:37 AM
Scottch's Avatar
I had this happen to me on an 87 camaro. Turn signals would stay solid, one turn signal would work occasionally, headlights would work only sometimes but not others, different combinations of non working lights. Turn signal dash indicator light was always steady. Headlight terminals were corroded back into the wires. Got new connectors and soldered them in and that solved all of the above. Probably just a bad wire somewhere. Hope you get it figured out.
Old Nov 29, 2011 | 02:52 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
since this thread is from 09, im sure hope he figured it out by now. most common issues for lights not doing what theyre supposed to is a bad ground, or a blown bulb.
on a side note, welcome to TGO.
redmaroz
Apr 25, 2017 07:14 AM
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
LittleFranks
Aug 20, 2015 03:55 PM
Cameeeero
Aug 20, 2015 03:06 AM
Street Lethal
Aug 14, 2015 08:25 PM
