92 rs fuel gauge issues
Old Nov 19, 2011 | 11:48 AM
alexquade's Avatar
Car: 1992 RS
its a 1992 rs, tbi. the fuel gauge is pegged out. all the way past full to the dash bezel. i unplugged the fuel sending unit plug at the fuel pump, turned the ignition on, and no change. where are the grounds at so i can check them, or could it just be my gauge is bad?? it just randomly did it. i was driving, at half a tank, and it just went all the way to the bezel... idk.
Old Nov 28, 2011 | 03:48 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Magic Tank Is Always Full
Here’s how to test the fuel gage.
Remove the sender wire going to the gage.
Tape the bare end of the sender wire and put it aside.
Use a potentiometer with a value of 100Ω or the closest you can find.
Connect one end the potentiometer to the gage from the location you removed the sender.
Connect the wiper of the potentiometer to ground.
Turn the key to RUN.
Slowly adjust the potentiometer from 0Ω to 90Ω.
If the gage is bad it will exhibit the problem you have.
If the gage is good it will display a smooth transition from one end of it’s range to the other.
Therefore the problem is with the sender or wiring going to it.
You can use a loose potentiometer, or you can throw together a quick little panel like this one.
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
Old Nov 29, 2011 | 03:15 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: 92 rs fuel gauge issues
usually fully pegged out means the gauge wire isnt connected to anything, giving a resistance of infinate and causing the gauge to peg out. itll do the same thing on the water temp gauge if its becomes disconected.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
