need 91-92 headlight wiring diagram
Old Aug 15, 2009 | 12:39 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
does anyone have a image to post or link for 91-92 headlight wiring?
thanks
Old Aug 15, 2009 | 07:29 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: need 91-92 headlight wiring diagram
Here you go. These are pulled from http://www.austinthirdgen.org/index.php?pid=19
They have pretty much all the diagrams posted for every system for each year.
I've attached the diagram for the headlights and headlight switch. If you need the tails and markers as well, they are at the link I posted above.
Attached Thumbnails need 91-92 headlight wiring diagram-diagram_1992_headlights.jpg   need 91-92 headlight wiring diagram-diagram_1992_lightswitch_exceptt61.jpg
Old Aug 15, 2009 | 11:41 AM
Bobby_80s's Avatar
Axle/Gears: no idea
thanks so much big help
Old Jul 21, 2012 | 08:32 PM
89camaroRSguy's Avatar
OMG thank you so much for this post. I've been looking for this wiring schematic for the headlights on my 89 forever. The manual I have has all of the wiring diagrams except that one. Been having an intermittent problem with my headlights working sometimes and not other times. Most of the time not. Now I can finally run new wiring.
Old Jan 25, 2013 | 06:43 PM
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
i can't freaking figure out whats wrong with mine, schematics are different on differend places, idk if my dimmer switch is bad or what, because the only lights in the car that dont work are all 4 headlights...
Old Dec 30, 2014 | 12:26 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Yes, I know, old post... but along the lines...
The headlight switch...
Is it just a simple switch, or is it acting like a relay to handle more amps than just a "connection"?
I'm going to extend wires and use other buttons...
I'll use relay's if needed....
Old Dec 31, 2014 | 07:31 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
The headlight switch is a high-amp capacity switch. I don't believe there are any relays internal to the headlight switch. And there are no external relays for the lights as part of the OEM wiring. I would recommend adding relays to the wiring for the headlights at least. Running a separate power wire, fused of course, from the battery to the headlights through a relay really helped brighten my headlights.
If you're planning on wiring in separate switches for the lights, relays would be the recommended way to go for all the lights. However, you could use a 20 amp switch for the marker/tail lights. The headlights will require a separate relay though.
Ghettobird52
Jul 5, 2024 11:18 PM
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
Jk_Under
Sep 2, 2015 10:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
