Oil Pressure Gauge Not Working
Old Aug 15, 2009 | 02:22 PM
tesla421's Avatar
Car: 92 Firebird
Engine: 3.1 V6
I have a 92 firebird v6. THe oil gauge only has lines on the far right side and the rest of the face is blank. The gauge stays in the middle where there are no lines. I changed out the oil sending unit and still the same problem. I then bought a mechanical oil pressure gauge and it shows good pressure. However, even with the oil send unit not plugged the oil pressure gauge is still staying in the middle. Does anyone know what could be the problem. I was thinking of getting a new instrument cluster from a junkyard and trying that. Is there anything else that could be causing the false reading. Wiring at the oil sending unit seems to be in good shape and getting a good connection. Any advice?
Old Aug 15, 2009 | 05:06 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Oil Pressure Gauge Not Working
This would indicate a bad cluster/gauge. Either the gauge is not getting any power or it's malfunctioning.
Do all other gauges work flawlessly?
Lou
Old Aug 21, 2009 | 10:46 PM
vulcanravenxvg's Avatar
Car: 89 RS Camaro
Engine: fuel injected 2.8 6 cyl
Transmission: Automatic
Axle/Gears: Stock crap
i have a similar problem with mine... execpt mine pins to max pressure at startup and stays pinned. and all my other gauges are fine minus the gas gauge which is a dirty liar most times... but is fairly accurate others.
Old Aug 22, 2009 | 08:52 AM
Pocket's Avatar
Car: 91 Trans Am
When the gauge stays maxed during run its the sender that usually the culprit
Unplug it and look at the connector. A bad sender will pump oil up into the connector pins
Old Aug 22, 2009 | 03:21 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
pinned gauge could also be grouded out on metal somewhere to unplug start car guage should read 0 the ground the gauge should pin it to max if so bad guage
Old Aug 23, 2009 | 10:35 AM
BigBadLou's Avatar
Engine: TPI
Tom, you might be thinking of the coolant temperature gauge which has an inverted resistance dependency. The oil pressure, however, has 0 resistance with no pressure and 90 ohm resistance at 60psi. So if the wire was grounded, the gauge would be pegged at 0.
Lou
Old Aug 23, 2009 | 06:34 PM
tom86iroc's Avatar
Car: 1986 iroc
DOH sorry your right i wasnt even thinking thanks man bad day over here lol
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
