Electrical wires to speed sensor
I have swapped my TH700r4 for a tremec tko600, and i have also purcased a new dakotadigital dash.. and the question is,
Where can i find the electrical wires that will fit with the speed sensor already installed in the TKO ?
I have looked everywhere with no luck,, hope someone can help me.
Sorry if this thread is in the wrong place..
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Electrical wires to speed sensor
I think Pocket meant a Junk Yard, aka Scrap Yard.
There are some online retailers that carry specialized connectors, I hope somebody will chime in with a link.
If not, you can always call your local dealer and order a new connector. Get your house deed ready, you might need to take out a second mortgage to pay for the connector.
Lou
Lou
JY = junkyard
You should find it under common acronyms
If you are unsure which connector to get snap a pic of the VSS in question
There are 3 types of GM VSS connector off the top of my head
db057
Aug 11, 2015 10:11 PM
