Wiring Harness
Old Aug 16, 2009 | 10:15 PM
therealjcamry's Avatar
Wiring Harness
Hey everyone, this is my first post as of I just joined. I just picked up a 1984 Camaro Berllinetta. Its in very good shape except the interior, basically nothing really works. My idea was to put a newer Z28 interior in it, ex. the 92' interior. Because the dash board is cracked and the guages barely work, I was thinking I should get a Z28 wiring harness possibly but, I'm really running into a dead end hiw to convert the car. Does anyone know what I'm talking about or where I should start???
Old Aug 18, 2009 | 08:45 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Wiring Harness
Berlinetta means digital dash, so Z28 anything wont work with what you've got
If you swap the Z28s dash and electronics in, you should be fine, albeit a huge pile of work
Old Aug 18, 2009 | 11:09 PM
Re: Wiring Harness
I know I have to get new guages and dash for the car. But I was wondering what type of wiring I need to get and for what parts, just the guage harness? Also like the speedometer is digital, what would I have to do to convert that, or is it just a speedometer cable?
Old Aug 19, 2009 | 06:34 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Wiring Harness
You will need the dash harness and cluster from the Z28 at minimum
The engine harness will have to be repinned to accept the new C100/C207 layout. Expect several runner wires to come with it and controls varied over the years
EX:
Berlinetta uses a VSS to send a signal to drive the speedo
Pre-90 camaros used a cable driven speedo
SD Camaros used an electric speedo
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
