Primary fan not working with air con removed
Old Aug 19, 2009 | 02:40 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I have the standard dual fan setup in my IROC. However, the primary fan does not come on by itself and I'm currently having to use a switch. I have removed the air con from the car and noticed the fan issue around that same time. Is there a link between the primary fan and the aircon that has caused it to not work automatically now the air con has been removed?
Old Aug 20, 2009 | 10:34 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
FANTASTIC
One of the fans was controlled thru the FAN A/C PRESSURE SWITCH.
You probably removed it.
How you restore operation is up to you.
You can make both fans come on at the same time, you can control each separately, etcetera.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look dorky. Turn em off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
Old Aug 20, 2009 | 07:15 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Re: FANTASTIC
I would like them to come on individually as they draw such a high current that having them both kick in at the one time is not ideal. Any suggestions on how best to get it working again?
1992rs/ss
Jan 31, 2025 05:10 PM
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
3rdgenparts
Aug 8, 2015 07:09 PM
