Need Help With Cooling fan
Old Aug 23, 2009 | 08:41 AM
Grosskhr's Avatar
Car: 1987 Camaro Base model
Engine: 2.8L V6
Transmission: 200C Automatic
Axle/Gears: Stock
Ok here is my issue, i have an electric cooling fan on my 87 2.8L last night it rained here and i was driving home in it, when i returned, i noticed the engine was overheating, the fan stopped running, so this morning i bypassed everything and hooked the fan straight to the battery and it ran just fine, so i know it is not the fan motor, also checked the fuses and all are good there, here is the catch, the previous owner hooked the fan up so that when you turn the key to acc the fan comes on, so it is always on until i shut the motor off. it is hooked into some sort of large relay on the passenger side by the battery and wrapped around (spliced) one of the wires to the fan. i have included pictures, and if anyone could tell me what that relay is called thank you very much.Need Help With Cooling fan-2.jpg
Old Aug 23, 2009 | 10:45 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Need Help With Cooling fan
Thats a relay of some sort for sure
Since the fan has been bypassed to come on with the IGN, sorting it shouldnt be hard
Most commonly the fusible link supplying the main power to the relay blows killing fan function
Test for voltage on the orange wire. No voltage = bad link
Fusible links are located on the starter and/or the power distribution block near the battery
Old Aug 23, 2009 | 10:53 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
That looks like the fan relay. However, the pictures are too small to tell the wire colors or analyze the splicing job. If you could provide bigger pictures, it would help a lot.
Or if you can tell us which wires are spliced where.
In the meantime, this troubleshooting article might be of help: http://www.austinthirdgen.org/index.php?pid=36
Lou
Old Aug 23, 2009 | 11:33 AM
Grosskhr's Avatar
Engine: 2.8L V6
Axle/Gears: Stock
the wire that has been spliced into is a black wire with a red stripe. there is voltage to the orange wire with a black stripe that is going into the relay. and when i turn the key to acc the relay itself clicks so i believe the relay to be goodand the two original fan wires just go into a wiring harness and dissapear, the wiring diagram dosent help it just says that the wire goes into a coolant fan relay, which i have no idea where it is.
Old Aug 23, 2009 | 02:47 PM
Grosskhr's Avatar
Engine: 2.8L V6
Axle/Gears: Stock
ok i found the relay for the fan and it is destroyed, it looks rusted and melted it has been this way for awhile, perhaps the reason for the bypass i have included pictures and also the connector is all messed up wires just twisted togother and wrapped in elec. tape i am going to replace the relay and connector and fix the wiring and see if it helps.
Old Aug 23, 2009 | 02:53 PM
Grosskhr's Avatar
Engine: 2.8L V6
Axle/Gears: Stock
Size:  4.4 KBhere is the relayName:  6.jpg
Size:  4.5 KBhere is the wiring
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
