92' power windows wont work
Old Aug 25, 2009 | 03:02 PM
mattnba44's Avatar
i got a 92' rs camaro v8. gauge lights wont turn on and windows wont roll down, also power lock works only sometimes. is there a blown fuse? wiring problem?
Old Aug 26, 2009 | 09:18 AM
NINΕ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
TAKE A BREAK
The widows have a common circuit breaker instead of fuses.
Check the breaker for 12 volts in and out.
The breaker is located in the fuse block to the left of the steering column.
The fuse block is located behind the knee bolster inside a door which is a part of the knee bolster.
RE: gage lights; do the radio or HVAC lights work?
RE: locks; divide and conquer.
Install a small light bulb half way in the circuit.
If it illuminates or not while you attempting to actuate the locks will tell you which direction to proceed.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look dorky. Turn em off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
