tach wire prevents ignition
Old Aug 25, 2009 | 03:09 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
I've got an 87 TPI setup, where the coil has four input pins. Two of these go to the pickup coil, one goes to the tach, and one is power. When the tach wire is connected there is no spark, but runs fine when it's disconnected. Is it possible to get the tach working again or do I need to chase down a new one?
Old Aug 25, 2009 | 08:10 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: tach wire prevents ignition
The real quesiton is:
is it the tachometer that's grounding the tach wire or is it the actual wire that's shorted somewhere under the dash?
If you pull out the instrument cluster and the engine starts, the tachometer is to blame.
Lou
eightsixseven
Dec 16, 2024 01:50 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
stalkier
Aug 7, 2015 04:49 AM
