headlight motor rebuild?
Car: 89 FORMULA 350
Axle/Gears: 327
I NEED TO REBUILD MY HEADLIGHT MOTORS. WHERE CAN I FIND THE PARTS?? ALSO HAS ANYONE HEARD OF SOME TRICK REBUILDING THESE MOTORS USING (ACTUAL GLUE STICKS). I KNOW SOMBODY WHO SAYS HE FOUND SOME POST ON THE INTERNET FROM SOME DUDE IN AUSTRALIA STATING THAT YOU COULD. HE SAID HE DID IT AND NO PROBLEM, BUT HE WAS UNABLE TO PRODUCE THE INSTRUCTIOS. OH YEAH ITS AN '89 FORMULA.
Axle/Gears: 3.45, 3.27, 3.27
Re: headlight motor rebuild?
I sell the kit. TDS 207280 headlight repair kit $6.75 includes the 3 bushings you'll need to repair one headlight along with instructions. TDS 209280 deluxe headlight repair kit $20.25 includes 6 bushings, motor housing gasket, 2 side cover gaskets, grease, two screws & nuts (to replace the ones that often snap off when you remove the motor from the actuator housing) and instructions.
Click on my banner ad over there--->
Or if my ad is covered by a toster strudel ad get them at www.Top-DownSolutions.com.
Lon Salgren
Lon Salgren
Car: 89 FORMULA 350
Axle/Gears: 327
REBUILT THE HEADLIGHT MOTORS. GREAT KIT. BEEN HASSLING WITH THOSE DAMN THINGS ON EVERY FIREBIRD I'VE HAD. I HAD NO IDEA IT WAS THAT EASY. THANK YOU!!!!!
1992 Trans Am
May 10, 2023 07:19 PM
